so ive noticed that some owners of the 7m put on a 2jz upperinintake. what would this entail and what are the benifits
Cya said:......or just get a front facing intake manifold which outflows the aftermarket 2j manis. Search for the Ron R. Custom intake manifold.
tte said:True...but you can get a 2j manifold for $200 shipped...
If you know a friend who could do the welding, then you good to go..except for the throttle body and cable relocation.
You could easily make a adaptor for your alternator.
And mkiv supras have put over 600 hp using the stock manifold.
So it is cheaper...
If you are a creative and innovative person , I am sure you could make what you need cheaper and save the money ofr other mods.
Cheers,
Roy
spoolint78 said:i'm going the same route as tte.
good setup, and makes the engine bay much easier.
tte, let me know once that mani arrrives.
did you get your lower runners already welded?
