suprastroker88;1647803 said:
Can someone give me the parts numbers for these items on a 2jz so I can go to the Dealership? Thanks
Front Main Seal
Rear Main Seal
Water Neck O-rings
Valve Cover Ventilation Hoses
Also....... Doing the 2jz swap, which fan blade do i need? a 7m fan or 1jz fan?
90311-46001 front oil seal
90311-90006 rear oil seal
96761-24023 water bypass pipe o-rings top and bottom
12262-46021 preturbo pipe to valve cover Vent hose
12264-46010 Inter-valve cover hose, front
12263-46010 Inter-valve cover hose, rear
12261-46031 PCV to intake plume hose
super.secret.supra.club;1648299 said:
DM sells toyota oem gaskets but without the stealership price.
for you fan set up use 94' lexus ls400 fan clutch and a 7m fan. lots of people have said use only the ten blade 7mgte fan but ive been doing well with a 7mge 7 blade. also if your motor is jdm you have to switch over to usdm water pump as jdm 2js' use hydro fan
so,
all your gasket need at DM
usdm water pump
94 lexus ls 400 fan clutch
7m-gte/ge fan blade
7m fan shroud
I wouldn't recommend the 94 Lexus ls 400 fan clutch. It's what I'm using and while it does fit, it sounds like it is on all the time. It's very loud. There are a few theories as to why this is(engine it comes from might spin it in the opposite direction, maybe the fluid viscosity is different) but it is loud. I'm still searching for a suitable alternative. So while it does fit I would not recommend it.
