2jz swap newbie questions
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
Ok so I've read through all the 2jz swap articles on this site, but I still have a few question.
Is there a difference in the ecu of a supra and a soarer? I don't want to go standalone right now.
Can I use an oil pan setup from an sc300 since it is a 2jzge?
Would electric fans cool better than a clutch fan setup?
Would the map-ecu or map-ecu2 be a good choice of piggyback if I'm using injectors bigger than 550cc or will my apexi afc neo be ok?
Sorry for the newbie questions. I'm new to the swap game and I want to do it correctly from the start
mkiiichip
1,434
WI
Yes there is a difference, the ECU connections are different.
Yes, SC300's are rear sump (as is a supra).
Electric fans have a few benefits, but better cooling is not one of them.
