2JZ swap. Keeping A/C and Power steering?
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
Hey guys. I just wanted to know if there were any alternatives to keeping the A/C and power steering than to make custom lines. Like using the lines off of another car. Thanks in advance.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
you dont need to make custom lines for either
P/S - either buy the MKIV one, or buy the line from DM line
A/C - swap the head from the 7M a/c compressor and you can use the stock a/c lines
tissimo
Stock is boring :(
Melbourne, FL
werd.. my old 2jz swapped car had a/c and ps.. I had a custom PS line (DM line or MKIV works though) and the 7m top plate and a/c lines. Worked flawless
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
the top of my 7m compressor plate wont fit, or did you do some major grinding in the p/s pump?
(wanted to also throw out there that the DM line will probably only work with with early 2jz engines 91-92 it wouldnt work with my 93-95)
tissimo
Stock is boring :(
Melbourne, FL
yea just grind the PS bracket.. its not too hard.. a bench grinder and you're good to go
you will have to remove the upper rear stud though. I sealed up the port on the 7m top plate, but it isn't needed. I've done 3 1jzs with a/c and I just moved the stud to the lower bolt position instead and didn't use the top.
tlo86
Jul 24, 2005
3,914
Colorado
which rear stud are you talking about? ( i need a picture with MS paint circles Lol :))
tissimo
Stock is boring :(
Melbourne, FL
see right under the a/c lines the stud with the nut? that one.. Just move it to the bol location on the bottom of the a/c compressor
tlo86
Jul 24, 2005
3,914
Colorado
i'll have to wait and do it when i get my next a/c compressor once this other engine comes in heh
SupraMario
I think it was the google
The Farm
Kristian_Wraae;1555891 said:
When using the mkIV PS lines do you remove the PS cooler? I don't see how the mkIII PS cooler can be retained.
I added a custom 9X3" cooler to mine, was like $40 from the auto store. Works fine.
jmcboost
Missouri
I flipped my PS cooler around so that it came through the drivers side of the front bumper area. I trimmed a little of it off and ran rubber hoses the rest of the way to it to make it work. Or the above will work I'm sure.
