2JZ Rev Limit on Stock Valve Train
csnow
Matthew 6:33
Palm Bay, FL
What is the safest rev limit on a 2JZGTE with the stock valve train. I am looking at a Gforce ECU to raise the rev limit but the two I have located are at 8200 and 8500 rpm. I think this is too high and I could blow the engine if I hit a slick patch of pavement or something. I will be running HKS 264s but the valve springs and retainers are stock.
Thanks.....
Chris
Boostage
323
Florida
Thanks.....
Chris
Chris you can float valves earlier than 8k depending on how much boost your running, but why not get some BC springs and retainers, they are fairly cheap. $330 and Powerhouseracing
