can you use aftermarket 2jz or oem 2jz parts on the 1jz for example spark plug cover ,adj cam
5l_eater I LIVE FOR THIS SHIT ! Jan 17, 2007 258 0 0 34 Maryland May 18, 2008 #1 can you use aftermarket 2jz or oem 2jz parts on the 1jz for example spark plug cover ,adj cam
8 88mkIIIproject Member Sep 10, 2007 482 0 16 39 Virginia May 18, 2008 #2 some parts are interchangeable, some are not. Cam gears are interchangeable. 2jz cams can be machined to fit the 1jz head (http://www.supramania.com/forums/showthread.php?t=55085). Check this thread for all the interchangeable parts: http://www.supramania.com/forums/showthread.php?t=29117&highlight=interchangeable Simple search on the word "interchangeable" is all it took
annoyingrob Boosted member Jul 5, 2006 2,304 0 0 Calgary, Alberta, Canada May 20, 2008 #3 spark plug cover is NOT interchangeable.
5l_eater I LIVE FOR THIS SHIT ! Jan 17, 2007 258 0 0 34 Maryland May 20, 2008 #4 so if i wanted to use a2jz carbon fiber cover i cant wow im blown
annoyingrob Boosted member Jul 5, 2006 2,304 0 0 Calgary, Alberta, Canada May 20, 2008 #5 yeah, the covers are completely different. The 2JZ one also covers the cam gears, where as the 1J has a separate cover for that. The 1JZ one also extends behind to cover the ISCV air pipe.
