2jz install in my 89mk3
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
Sorry in advance, i realize that this question has probably been answered a lot. I'm ordering my 2j vvti besides the wiring, is there anything special that i need for the install?
Thank you very much everyone for your help.
:icon_bigg
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
i just wanted to know if someone could give me a parts list that i can start looking for parts.
thanks again.:icon_bigg
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
I searched "2jz parts list" and almost instantly got what you're looking for. I suggest you do the same, and click on the third thread down. Oh, and by the way,
SEARCH NEWB!
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
Alright guys thanks for your time and for not freaking out on me. I'll search a lot more. Just figured someone on here could just tell me without me having to search. But thanks dudes!:icon_bigg :icon_bigg
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
dude, what the hell!? u want somebody to help!? Search is there to help! just about every question u could ever ask has been answered here already in one thread or another. why hope that somebody is going to spoon feed you? are u that lazy!?
I bet your car is older than u. :3d_frown:
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
calm down jaguar. dont really need that attitude on the forum..
check out my thread mk3 bamf i have pretty much everything listed (from an 89 turbo automatic to 2jzgte manual)
vvti is going to be interesting thats for sure :) i actually wouldnt have minded a vvti... although the cost of someone to do my wiring is what would worry me hehe(i wouldnt even attempt to do that myself :p)
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
i'm actually going to get the automatic set up. and turn the manual transmission into the clutch-less manual, can't remember what you call it right now, later when i can afford to. and just run automatic for now.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
is it just the 1JZ VVT-i or are both the 1J and 2J VVT-i built with really weak rods? i remember someone saying the 1J VVT-i could only take about 400 whp before con-rod failure
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
It's sequential, I have to run auto or sequential because I have Muscular Dystrophy and physically can't deal with a clutch.
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
IJ. said:
Bamf: Look into the SupraStick V4 it's a programmable trans controller that lets you shift manually with paddle shifters or buttons.
I wired mine into the ect/pwr buttons.
Thanks man, Ill look in to that right now.
tlo86
Jul 24, 2005
3,914
Colorado
suprastick wont work with 2jz transmissions only 7m and 1jz unless you are wanting to use a 7m/1jz transmission on a 2jz? (you would have to wire the 2jz's ecu to think its in neutral all of the time)
I thought he was swapping the Jz into an Auto Mk3?
Keep the 7M trans and converter swap in a Jz bellhousing and he's good to go ;) (much less drama and expense than building his clutchless manual he wants and still has full manual control over the trans)
tlo86
Jul 24, 2005
3,914
Colorado
honestly im not exactly sure he wants to do lol!
the a340e from the 7m is the best way to go along with a suprastick. (you just have to wire the 2j to think its in neutral and use a throttle cable from transmission in place of where the cruise control hooks up to the throttle body) assuming you want to keep ABS and such (newer jz transmissions dont have the abs sensor on the tranny its on the rear wheels and used for traction control as well)
Tlo: Jz 340's have electronic line pressure control so no cable.
Bamf has a disability but would like a manual car and talked about building a clutchless manual (huge expensive job) I offered up the SSv4 as a low cost alternative.
My SSv4 has been brilliant :)
