2JZ - Hoses
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
For those who did the 2JZGTE swap into the mkIII, what yr hoses did you buy to raplace the Radiator hoses - upper and lower?
Also,
The oil feed hole - What is the fitting that I need ? What size thread and what not.
Oil Drain - what fitting did you use here?
For a Journal Bearing turbo, what size whole should there be on the oil feed adaptor? Right now it is very small about 2-3 mm but I think that is for BB turbos.
Thanks.
