through id throw up my issue.
car breaks down around the 3k mark at idle and in every gear. including reverse.
how most times if its 100 accel it only breaks down for a second or 2 then continues to rev past it how ever at a massive decresses in power.
if its under 100% accel then it hits 3k rpm breaks down and continues to break down untill u lower the rpm down. or rev it 100% when it breaks down at lower throttle the car feels likes its going to stall it jolts that bad. when it hits the 3kish rpm mark.
2jz has been put into a silvia s13. with a to4z turbo on the side. 255lp walbro fuel pump. fuel reg. standard injectors. and ecu.
changed plugs No change at all..
swaped coil packs didnt make any difference.
i still have the standard FPD on the motor and inuse. not sure if this would cause any restriction to fuel or not.
bypassed the standard FPD and ran a line strain from the fuel pump to the fuel rail. ( didnt make any difference. )
FPR is running 40psi at idle rising rate.
. does any one have anyidea on what i can try to fix this ??
i have also swaped the map sensor. and ecu over with different ones. with no luck.
Car loom and computer are auto. how ever i haev converted this to manual. and then had it wired into a s13. could using a auto computer be causing this issue as its not getting a signal from the auto tranny that it should be ?
any help would be great.
motor is a jap motor 2jz-gte as well.
currently looking for a ecu to swap over to see if that fixes the problem and a ingnition module as well to borrow to see if either of them fixes this issues.
