will the 2jz gte cams fit into the ge? i have heard some say they will with light machine work... does anyone the extent of the work that has to be done. i know that the gte has a cas and the ge has a dizzy so i also wondering if the front plate off the 1jz which houses the crank angle sensor will bolt onto the 2jz-ge block?.
