2jz-gte AEM EMS stalls on idle
supramk3turbo
53
Norway
Hello :)
I have a little tricky problem with my 2jz-gte...
Specs:
- 2jz-gte J-spec in an Mk3.
- Greddy T78 turbo
- Sard 850 cc injectors
- ICV Removed
- Aem ems 1100
Problem:
As soon as the RPM goes to 1000/1100 rpm, the engine dies... know mather if its cold or warm, it will not run on idle :/ This came suddenly, it has been running fine for 2 years until now.
I know that the aem and the map is working, so the problem is most likely not there... i tried it on another car, and it was running fine.
When i connect my computer to the AEM i can read all data from sensors and so on, everything looks normal.
Any ideas??
Can it be a earth problem in the wiring somewhere??
Thanks.
supramk3turbo
53
Norway
Sadly it is not, i have checked this many times... I do have a feeling that there is something in the wiring harness that is kidding with me....
