Can one of you flow chart gurus tell me if I can run the GT4088 at 18 psi safely on 550cc injectors on a 2J or whether I will need to go with larger injectors.
You might be ok with 550s but what if something happens like an unexpected boost spike or boost creep and you don't have enough injector to handle it? That would suck. :|
from what I remember when flowing the GT40-88 out for the 1JZ, it maxed out 550s around 20psi. The 2JZ will max that turbo out much sooner.
Dont' quote those exact pressure ratios, as I was calculating for my elevation, and even then, it was a while ago, but this turbo will max out the injectors. Get a set of 800cc injectors, that's what I did
