So I swapped a 2jzge from a 92 lexus sc-300 into my 90 mk3 supra.. Here is what is happening.. It idles fine and revs up pretty good and smooth tilll about 2500 rpm then starts breaking up very similar to like a 2step.. If you hold the throttle it will still keep breaking up but will still rev higher in the rpm's even tho it is breaking up like crazy.. Same exact thing when free reving it and when driving it down the street.. Here is everything that has been checked and gone over so far so you can eliminate it from the potential causes..
-New timing belt and engine timing is spot on and has good compression
-Ignition timing is set to 10 degrees BTC at idle on the #1 wire
-New TPS sensor
-New Distributor cap and Rotor
-New plug wires
-New ngk platinum plugs tried gapped at oem spec .043" and gapped em down to .030" and pretty much same result mabe a little better with tighter gap
-Listened to injectors with stethoscope and all seemed to be clicking the same so no stuck injectors
-Ohmed out ignition coil and it checks out
-New maf sensor
-Stock ecu and complete wiring harness
Any ideas of what else it could be to be causing the ignition miss???? Im just about out of ideas
-New TPS sensor
-New plug wires
-New maf sensor
