2jz ffi ?????????
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
where do you get a 2jz front faceing intake and how do you put one on a 7m i know there is some cuting and welding but does the tb fit and how do you mount it cut a new flange and weld or cut and weld runners or the box itself? pics would be awsome
Turbosidosis
PVC FTW
Houston (Sugar Land), TX
Most people take the lower runners for the 7M and 2jz, cut them, and weld them together. I don't know much about it, but I think the 2jz TB is used with a little modification, you have to rig up a bracket to use the 2jz throttle cable, and make custom IC pipes. There are some good write ups about it on supraforums, I saved the links on my home computer (I'm at work). You should be able to search and find them, it seems pretty easy for what you get.
I have a 2jz intake, TB, and lower runners with all the sensors and attached hoses I was going to put on my 7M before I decided to go 1jz. PM me if your interested. ~John
Jspec7m88
1,583
Nappy City
After it's all said and done, For what I think money wise would go, You would be better off getting Ron's kit! I am positive the 2JZ IM is very productive...but getting Ron's kit includes Alternator drop-down brackets and all the necessities to run FFIM.:)
