2jz bellhousing
The 2jz bellhousing will fit the 1jz motor. What transmission is it coming off of? If it's off of the auto then it will fit. I don't know about the V160.
tissimo
Stock is boring :(
Melbourne, FL
Evilempire1.3JZ-GTE;1209528 said:
The 2JZ bellhousing will mount only the 2JZ transmission that comes with the bell housing to the 1JZ or 2JZ block.
Not true.
You can take a 2jz W58 bellhousing and mount it to a 7m W58 trans and itll work fine.
tissimo
Stock is boring :(
Melbourne, FL
Looking at the OPs post, I think me means a w58 bellhousing to a r154, and no it will not work. The only bellhousing that will work is from a 1jz.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Sorry was giving the awnser too short.
You can mount the V160 or V161 to either the 1JZ or 2JZ
As a 1 piece tranny it doesnt have diffrent bellhousings.
You can mount the R154 to either the 1JZ, 2JZ or 7M (Tech: the chevy ecotec as well)
You can mount the W58 to either the 1JZ, 2JZ or 7M also.
All you need is the proper factory bellhousing to go between them.
