FYI.... Here's the link to the Aristo's body plug pinout I was working on. Note that it actually consists of 4 different plugs in one larger one (Thanx for the info Arnout).
http://www.geocities.com/g099521/MKIII/2JZ_SWAP/pinout_test.xls
I suggest you print it off and make/label your connections and document them. If anyone else has more info/suggestions please let me know and I'll update the doc.
I am using the body plug as an intermediate connection point. Once the swap's done and all's running well, I will probably eliminate the unused wiring and plug... I have the 7M engine harness connectors I'm using to the dash, as well as a generic one that I am using for the auto connections at the plug that would've gone to the 7M ECT.
I am all FUBAR from messing with the wiring today, having a cold, and a few Rum & Cokes. I can really use some examples of how to run/connect the 3 EFI/12V power wires from the junction box. Do they go to the engine harness AND the dash plug (B1?).
Anyways, I hope this stuff helps enuff ppl to just get on with the swap and not be overly intimidated by the wiring. Thanx for all your help and support!
E
E
