2jz 240sx swap
dillards1234
13
florida
Hi, I have a 1992 240sx with a 2jz swaped into it and i was wondering cause im replacing the timing belt if the belt goes on wrong will it freeze the engine or not. And if anyone wants any info or parts to make this swap work go to tech2motorsports.com.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
well it shouldnt go on wrong in the first place! :)
http://www.turbosupras.com/pages/en/pages/technical/a80tsrm.htm go there be happy!
Tim
regular member
Oct 16, 2006
272
CA
its pretty hard to screw that up, Just line up the cams and the crank gear and release the tensioner and you are set. Very hard to screw that up:biglaugh:
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Hey tim, sorry to be Mod-like, but your sig is waaaay to big. I think its only allowed to be like 145 pixels high or so.
Ok, back on topic.
93kyumaru
JZ Master
Oct 31, 2007
Japan
BlackMKIII is correct it is non-interference (pistons will not strike the valve) unless you have some huge ass cams in there.....
Tim is also right pretty hard to screw up but remember there are two marks on the crank pully use the left mark (should be painted white)
