So I am pretty much done with 99% of the physical work in my SC300-T swap. I have been using a lot of information posted on http://www.1uzsupra.com Granted the 2JZ and 1UZ are different motors but they both integrate very similarly into the SC300/400 chassis and harnesses so forth.
I have been reading and decoding Bryan and Mikes posted PDFs on how to sort out the wiring.
I have decided to make it a little easier to decode and lay out as the formatting and definitions of what wire corresponds to what gets lost in the arrows formatting
So I basically made this table which is straight forward. It pretty much eliminates all the guessing as to what the PDF's and pictures mean.
This spreadsheet documents MIke's and Bryan's work as posted on the website. What I would like is to better understand what is connecting to what. I think this sheet will simplify a lot of the guess work and make doing this swap a little easier. As I gather missing information I will update and repost the sheet to reflect the new data.
I will also try to correctly identify all the Plugs and name them correctly.
I would also like to identify the function of each wire so we know what is doing what. This could always help troubleshooting electrical gremlins in swaps.
Some Questions I have:
Do I have to supply switched power and ground to the SC ECU? of will the wiring and spliced accomplish that along the way? I have not tested to see if my ecu has power with IGN-ON yet.
LINE21-22: Do i have to run 10-12gauge wire from by 7M fuse box to under glove box?
LINE23: Fuel I have no idea where the green wire goes nor do I see a reference white/black wire? Help?
I hope Bryan (Viper92086) can chime in since he is local.
Got all the rusty crap of the car and installed some new/used now primered parts in place ... and opened his eyes for him
