I have a drewgo t4 manifold and downpipe. The turbo is a precistion t67.
For some reason the downpipe (3-inch) won't fit because it is rubbing up against a coolant outlet/inlet. It is rubbing to the point that I can't even get the downpipe to sit flat enough against the turbo to connect the vband clamp (no matter which way i place it).
I know some folks have had a downpipe sitting real close or up against this outlet... But has anyone had this problem where it wouldn't fit at all? What did you do?
The larger outlet in the center of this picture is what i am talking about.
http://www.boostlogic.com/install_manual/wastegate.jpg
I'm guessing I'm just going to have to get a custom downpipe.
