2j in 89 mk3
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
lookin at post it doesent make sence that the swap would cost upwords of 10k. Im geting my 2j and the 1j bell and 7m cluch and my 5 speed. then I was going to put it in then was going to have a shop wire it and start it.
crazysupra2JZ
740
Georgia
mine was just over 6k, with a single turbo swap and all the supporting mods for it.
i also did all the work myself, as well as the wiring
crazysupra2JZ
740
Georgia
so you should be a little below 5k then for the swap, as long as you do all the work. the wiring is tough, but can be done, it will take some time
crazysupra2JZ
740
Georgia
http://www.supramania.com/forums/showthread.php?t=45587
2JZ-GTE From Aristo...................$2100
BIC Motor Mounts........................$180
1JZ Lightweight Flywheel..............$310
7M Spec Stage 3 clutch kit...........$475
1JZ ARP Flywheel Bolts..................$30
1JZ Bellhousing...........................$320
94 MK4 Mid Sump Oil Pan..............$550
94 MK4 Throttle Cable (worked perfect for me).....$65
Walbro 255 LPH Fuel Pump...........$110
Single turbo Exhaust Manifold (only if you don't want to modify firewall)......$160
1JZ Power Steering Hose.............$100
Aermotive Fuel Pressure Regulator.$140
94 MK4 Water Pump (if you don't want the hydro setup)....$150
94 MK4 Pulley kit.......................$70
Wideband 02............................$280
Turbo kit from XSPower..............$350
all that info was gathered on my old 87. but all the parts needed are the same, just have to get the 89+ mounts from BIC instead of the pre89
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
look at my build thread i have a list.
might be cheaper to go for 1jz mounts(if rubber part is bad you can reuse 7m's), parts store P/S line from a 2jz (mine was 58$) and i bought my lower pans for 150$ that was from a 1jz and included oil baffle, pickup, bought a new gasket for the pickup, gasket material for pans, etc etc
i would buy new bolts for the lower pans too... every time i torqued mine the head broke off :) and set aside about 1000$ in alittle stuff" fund. oils etc
lots of other stuff to factor in. be prepared to have your car down a long time crazy worked on his for a while heh
i would urge you to do something like a 1jz :) i kinda wish i did at this point
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
how much do you what for it? I have 1500 to start my project so I thinke I mit go with a 1j so I can just get the car done.
