supramanocnsd;960345 said:13psi safe?? umm factory on a 2jz-gte is 10.8psi... boosting a factory USDM set of twins to 20psi is correct for a drag strip.. a street setting would be 14-18psi depending on the GAS and the driver... I have seen many MKIV TT owners like myself run 24psi daily and have had great fun.. it will be ok at 13 .. but better at 17psi...
supramanocnsd;975442 said:True ed.d
Well he can do the bleader T and other less expensive mods from www.mkiv.com and save some cash but wont beat that many cars if he is looking to be some sort of a street hero.. lol
supramanocnsd;977084 said:ummm I have seen a ton of BPU auto's laying out BPU 6speeds... its about getting the power to the tires and ground...
The light weight would be good.. I just dont like the body style... I am 6'1" and dont fit in Z cars well at all
foreverpsycotic;977279 said:True, but with the gearing of the Z, you will want the 6 speed. Its around a 3.3. Comparable to driving a MKIV auto with a 6 speed dif.
Does the extra inch make a difference, im 6' and feel like a Z is quite comfortable.
Rennat;978262 said:i dont see how you could get the datsun to weigh 2900 lbs... it comes stock with an inline 6. so replacing it with another inline 6 wouldnt do much... i dont think it would hit more than 2600LBS... given the trubo stuff adds a little weight... but not that much.
dryweight is 2355lbs according to a wiki article...
http://en.wikipedia.org/wiki/Nissan_S30#Specifications
supramanocnsd;978320 said:I would never put a 6speed diff behind the 3040le... the stock auto TT diff has a way higher gear rat...
