well i finally got an aftermarket boost/vac gauge and put it in yesterday....... according to the gauge i'm at 20" vaccum at idle i can get it to about 28" if i snap off the throttle while cruising. I was thinking these cars should be running around 15" or so am i wrong. Also the other thought i am having, i think my new gauge might not be completely accurate..... my stock boost gauge peaks under full accel at around 7psi +/- .5psi the aftermarket ( a Faze BTW) only peaks at 5 which to believe???? Oh, not to make this any longer than needed, but i have one other concern (as this is my first dealings with a turbo vehicle) should it take running through first gear at full throttle to finally get boost as soon as i pop into 2nd??????? thanks guys
