2 Quick Questions... (ISC and K/S related)
Hey guys,
I'm finishing up my build and there are a few small details that I am a little confused about:
1. The 2 visible tubes on the ISC valve run to the intake pipe pre-throttle body, correct? I no longer have my 3000 pipe and I forget how it was plumbed. Then the other tube that is kind of pointing down goes to the metal vaccuum tube assembly thing. Is that right? The last time I reassembled a 7m it was a GE and the ISC plumbing is different.
2. I am reusing my 7m-ge block but the wiring harness is from a 7m-gte. The GTE has 2 knock sensors but the GE only has one. If I leave one of the connectors unplugged, will that cause a problem?
Thanks in advance,
-Nick
IHI-RHC7
"The Boss"
Oregon
There are three "tubes" on the ISC, the big one goes to the accordian pipe, through a hard pipe next to the 3K pipe. The other two are for coolent.
I bypass the coolent lines, unless the car is going to reside in alaska, or russia.
The GE block has threaded bosses for 3 knock sensors, just like the gte, move the center k/s forward, and insert a second k/s into the rear hole, leaving the center hole empty.
Thanks for the help! I appreciate it, and yeah...I kinda thought I was wrong about that.
My GE block has all three bosses but the 2 unused ones aren't threaded.
I looked at the cracked GTE block I have and the unused boss on there is threaded.
So, I'm guessing I have to drill and tap the other 2? I'm really not too excited about drilling and tapping cast iron...
Also, since I now know that this doesn't go to the isc, what does the tube in the attached picture go to? It doesn't show where it goes on the vaccuum diagram I have.
Thanks again!
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
I believe that tube goes to the BOV, or at least that's where it routes to on mine.
I can't help ya with the KS though...tig welder maybe? :D
the tube in the picture? really? hmmm I wonder if I can just plug it then since my aftermarket bov will have vacuum from a different source...
Unless you ment the ISC tube, but I got that figured out.
Anybody know about the knock sensor? What would happen if I just leave one unplugged? Or possibly solder the wires from the unplugged k/s to the other one to trick the ecu?
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
yea he's right unless igot lost it goes from there between the intake into another metal pipe, then out to the bov
