2 problems......
Destroyer101k
23
1st problem is every time i get into a freeway, or go above 65, the check engine light goes on BUT nothing goes wrong. everything works fine the light just turnson.. any ideas wat it is???
2nd. so approximately 6 months ago, i turned on the car like always. as i was driving i came up to a turn. i turned and the check coolant light came on, then turned off, it keep doing this for 1 week, and i DIDNT see the temperature rise it stayed normal, in the middle. i just filled it up and the light wouldn't turn on anymore. 2 months ago it did the same thing, i did the same thing too. just this weekend it happened again and today too... anyone know wats going on.?? ideas??
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
1. O2 Sensor...? Have you pulled codes?
2. Is it the Birdcage light? Small coolant leak...hose...rad cap...bhg...?
CajunKenny
Nov 15, 2007
3,255
Washington
Definitely start with pulling codes.
Did you check for leaks with a Coolant Pressure Tester? If you have a plastic cap rad and it is old, that could be the culprit.
