2 BOVs?
casper35404
165
Tuscaloosa, AL
I just put the HKS SSQV on my car. I was wondering if I could run the SSQV and the stock recirculation valve if I had a "t" connector on the little vacuum hose. The reason I'm wanting to know is because I have a good bit of turbo chatter. Any help would be appreciated.
mkIIIman089
Ohio
oldschool85 said:
at higher boost that stock BOV means nothing.
charlie
True, it will be cause for potential boost leaks at higher boost. Well, any bost above stock and its about ready to let go. So can it be done? Sure, but you may at least want to replace the stocker with a Bosch for security against leaks.
