The 1UZ-Powered Supras site will follow my project build as I swap out the 7M-GTE engine in my 1987 Toyota Supra for a 1993 Lexus SC400 1UZ-FE engine. I will keep a detailed project log on the site for all to view and refer to as well as provide links to various sources such as other enthusiasts’ projects, automotive forums, and vendors. I will also attempt to update this build thread as often as possible.
I am currently looking at a multi-stage build-out:
Stage 1 (Year 1, November 2007 - April 2008)
Get the motor installed with the R154 manual tranny, wired, and running by the spring thaw. This will require engine mount fabrication, bell housing adapter fabricated, new exhaust, hybrid wiring harness, ECU, misc. hoses and cables, electric fan setup with thermostatic switch plus manual switch in parallel for backup, flywheel, clutch and pressure plate. If I want to keep it, A/C will also have to be re-plumbed and recharged as well.
