First #'s with the 7m:
updated 250rwhp/266rwtq
Current setup is:
rebuilt block bored .020
toyota .020 oversize pistons
8.9:1 comp ratio
cometic HG (surfaces prepped to 17.3RA)
no other head work, should've P&P'd
wastegate shimmed w/ 2 washers (roughly 9psi)
base timing 12deg
91octane pump gas (yay! - the 6m-T required race gas)
still have slight irregular miss & top end could use some leaning. I'm considering grabbing the MAF-T Pro rather than installing the AFC. If I can just cure this *$&#$*(@! irregular miss so I can get my car legal, I'll start pushing to boost more around 15-18psi.
Current setup is:
8.9:1 comp ratio
base timing 12deg
