1jzgte is having starting proplems in the cold
sp617m
68
Prescott az
so my 1js having proplem's starting, but didnt start having this proplem till the weather got cold here. it trys and trys. I have two clips that will give you an idea of what it does. please any help will be really apreciated thanks.
  • 1109112117.wav
  • 1109112120.wav
te72
Classifieds Moderator
6,619
9
WHYoming
Does it crank and start at all? If it will start, but then die shortly after, try holding the throttle in just a bit. If it stays running, it might be your IACV.
sp617m
68
Prescott az
last time i checked was the first time it happen and only had a 24 Intake air Temp Sensor Signal. but ill check when i get off work.
sp617m
68
Prescott az
well would that cause it to have cold starting proplems cause I had that code when it was warm and it would start fine. Just wondering.
kneedragger85
363
Boulder, CO
Yes! Usually when there is a fault with a sensor like that, a default value is substituted which would be a value when at normal operating temps. Fix the error code/sensor issue.
