So I have always wanted a supra and finally got one.It is an 87 mk3 with a 7mgte motor.The only problem is it has a knock.I did some research on the 7mgte and read that the crank isnt balanced right from the factory and the head bolts are not torqued to the right specifications.I would also rather it be twin turbo so I decided To get a 1jzgte motor.I was going to order the motor off of J.D.M and was wondering if the motor would mount up to the 5 speed tranny I have in my supra now.I was also wondering if i could use my blow off valve and turbo from the 7mgte motor since the kid included a brand new turbo and HKS blow off valve with the car.:1zhelp:
