Hi all, just recently had a swap done on my MK3, had a 1JZGTE installed stock twins only 25k miles on the motor with some extra goodies to match. Tried searching up the issue but really haven't found anything relating specifically to how mine sounds. That aside here's the issue;
On a cold start, I can turn my key once and boom it turns over. Idle will be a little rough because I was told the IAC Valve is out/going out and so idle is manually set. This could be an issue but either way I'm unsure because I'm not too tech savvy with the 1JZGTE or specific parts.
Anyways, after running for quite a bit, usually the time between my drives somewhere are around 15+ minutes no more than that. I get to where I'm going and leave the car for a bit, say I start it again another 15 minutes later, and I have to hold the key over for maybe about 5/6 turns (while pumping the gas pedal) till it finally turns over.
Battery is brand new, as far as electronics go I have a Kenwood 500w AMP in the rear, Pioneer double din head unit, GReddy Boost Controller and Turbo Timer, Python 990 Remote Start 2-Way alarm system, and I don't know what else at the moment.
As well an unrelated issue that has just been pestering me; sometimes when I drive my radio and boost controller go out (boost controller is wired through radio "ACCESSORY") but If I put pressure on the fuse box at the kick panel literally everything turns back on. Any idea what I'm dealing with there? Sorry for the 2 separate questions but I just remembered that.
Thanks in advance guys!
-Dimitris
-Dimitris
