I wanted to post something i found during my swap that helps those doing a 1jzgte swap. I tried searching around to see if someone had posted it but the search engine in here wouldnt let me. So i dont know if someone has posted it already but here it goes
The honda/acura NSX has the same ecu plugs as the 1zgte. so if you go to www.boomslang.us and email them for an 18" NSX extention ($215 shipped) you can plug your 1jzgte ecu and harness together and go through the firewall like stock. If you cut the loom off your harness and stretch it out as much as you can it will tuck behind the engine and behind the charcoal canister. then its sort of a pain but you can clip the harness extention in along with your body plugs (got mine done throw driftmotion for $85 iirc) and hydro fan (if you use it).
All in all $300 wiring conversion if done this way. Not to bad. Just thought id post it up. Like i said the search engine didnt like the "nsx" in it.
