Well this is kinda long i'll try to throw in pictures because they are worth 1000 words and all.
Well the cam cover bolt backed out after a adjustable FPR isntall
and well torn up the belt pretty bad, but after startign a timing belt change we found a lot more.
it chewed up the crank timing belt gear which is almost $80 to replace! :cry:
also hurt the ckps bad enough so the car would not start
So water pump came off to be replaced, tensioner replaced, cam gears removed, while we were at is we took the valve cover off to place the leaking seals. i think some more too i can't think of right now.
Clean huh :biglaugh:
this is where i got it now. I'm still waiting on a new ckps and cam seals.
tomorrow?
well i have a suby Down/Up pipe to in the morning than find a ckps ::hang:: and put everything back together.
so yeah, one bolt.... did all this
but at least it's clean now!!!
tomorrow?
