White is usually the OX signal. Check it's continuity to the OX pin in the diag box. For the other two. One is heater wire which also has a pin in the diag box. The other is just a +B so check continuity to injector power or just unplug the ecu and see which one has power. iirc the blk/red is +b and red/blue is heater. If your heater wire has a green tracer for what ever reason just check it's continuity.
The two black wires are for power/heater. You can flip flop them it's 12v either way. Lemme guess it's a bosch sensor?
Tlo86: please be careful about assigning ground to white wires like that he could really damage important electricals! In toyota Grounds are ALWAYS brown or white/Black tracer. And hooking up the HT wire to the signal will fuck the sensor
Sorry to bust your balls like that I'm just looking out for him
