Hi, i am looking for a wiring diagram for the 1jzgte vvti i just got. i do not know from what car it is out of, i read that it could be from a JZX110 markII or a verossa since i got the throttle control ECU (drive by wire) but then again if i look up the ECU number it tells me the JZX100 from a chaser. it is mated to a r154 (5speed tranny) I am doing this swap into an 92 sc300 with no drive by wire system. so i am wondering if it will be possible to use the cruse control butterfly as the "new throttle body" and use its position sensor or relocate the tps that is on the DBW system to the "new throttle body" location and rewire it to the aclual ECU so the throttle ECU is cancelled?
What is this Track ECU I do not have this (would it be the Throttle ecu)?? I know it is probably for traction control and is probably some of the connectors hanging close by the car ECU??
if someone can help me with diagram that would be appreciated
the ecu # is 89661-22790
i need the pinout for the 4 connectors i just got the 2 harness connectors the body connectors were missing here are the colors on my 2 connectors.
Also if someone has the 92 sc300 5speed body connector pinout that would be helpfull
the ecu # is 89661-22790 everything after the  sign is information I collected online and not sure if it would apply to my ecu and the way I want to wire my throttle, wires color is what i got on my connectors.
34 pin connector “J”
1-(no wire)
2-(no wire)
3-G/Y  VT01 – trac ecu
4-(no wire)
5-R/BLK  #6 injector
6-BLU/R  #5 injector
7-R/W  #4 injector
8-G  #3 injector
9-BLU  #2 injector
10-R  #1 injector
11-(no wire)
12-Y/G IGF ignitor
13-BLK/W  STA starter
14-(no wire)  Neutral start switch ( no wire on my connector)
15-W/BLU  OCV-
16-W/R  OCV
17-(no wire)
18-BLU  ETC
19-Y VE
20-Y/R ISC4
21-G/W ISC3
22-BLU/Y ISC2
23-R/Y ISC1
24-W/G  IGT1
25-BROWN EVG
26-LIGHT GREEN E1
27-PINK ETC
28-(no wire)
29-CLEAR knock2
30-CLEAR knock1
31-BLU/W IDL2 - track butterfly
32-(no wire)
33-W/BLK  E02
34-W/BLK  E01
22 pin connector “I” “B1”
1-BLK/Y VC-TPS
2-(no wire)
3-(no wire)
4-(no wire)
5-BLK/W NE+ check connector may be not necessary depending on how FP is wired??
6-G NE-  connector H pin 10??
7-Y/BLK VTA1-TPS
8-G/BLK  VG  connector H pin 4?
9- (no wire)  COR power (splice for all blk/r wires, power for ISCV, all VSVs and B on diagram connector??)
10-R VVT
11-(no wire)
12-Y/G VTA2-Track butterfly  splice off of this wire for connector J pin 13??
13-LIGHT PINK  OX
14-G/R VT02-Trac ecu
15-(no wire)
16-BLU IGT3  IGSW connector G pin 9??
17-PINK IGT2
18-(no wire)
19-R/Y  HT
20-B/Y  THW
21-R/W THA
22-BROWN E2-TPS
16 pin connector “H”
1- NEO-TRAC ecu
2- MREL  EFI main relay C1 pin 2??
3-  FPU VSV check engine M1 pin 8??
4- FPR-Fuel pump relay B1 pin 8??
5- TE1-Diags blocks
7- EFI+ - Track ecu
8-  EFI- - Track ecu
9- FAIL- Track ecu
10- FC-COR Circuit opening relay B1 pin 6??
13- PRG-VSV
14- ABV-VSV
28 pin connector “G”
5- ACMG-ac mag clutch
8- EGW- to dash led
9- IGSW B1 pin 16??
11- TE2-diags blocks
12- SPD- speed sensor from dash used to enable VSS (not necessary to connect)??
13- CCO- Diags blocks
14- BATT C1 pin 1??
18- EFIF-TRAC ecu
19- AC2-AC
20- a/c
21- ELS2-Defrost Idle up M1 pin 10
22- +B – EFI relay  B1 pin 9 (splice for all blk/r wires, power for ISCV, all VSVs and B on diagram connector??)
25- STP-Stop light switch 1L pin 10??
26- THW0 - AC
27- ELS3 rd fan 1
28- ELS1 tail fuse
1-(no wire)
2-(no wire)
4-(no wire)
7-R/W  #4 injector
8-G  #3 injector
9-BLU  #2 injector
10-R  #1 injector
11-(no wire)
12-Y/G IGF ignitor
15-W/BLU  OCV-
16-W/R  OCV
17-(no wire)
18-BLU  ETC
19-Y VE
20-Y/R ISC4
21-G/W ISC3
22-BLU/Y ISC2
23-R/Y ISC1
24-W/G  IGT1
25-BROWN EVG
26-LIGHT GREEN E1
27-PINK ETC
28-(no wire)
29-CLEAR knock2
30-CLEAR knock1
32-(no wire)
33-W/BLK  E02
34-W/BLK  E01
1-BLK/Y VC-TPS
2-(no wire)
3-(no wire)
4-(no wire)
7-Y/BLK VTA1-TPS
10-R VVT
11-(no wire)
13-LIGHT PINK  OX
15-(no wire)
17-PINK IGT2
18-(no wire)
19-R/Y  HT
20-B/Y  THW
21-R/W THA
22-BROWN E2-TPS
1- NEO-TRAC ecu
9- FAIL- Track ecu
13- PRG-VSV
14- ABV-VSV
18- EFIF-TRAC ecu
19- AC2-AC
20- a/c
26- THW0 - AC
27- ELS3 rd fan 1
28- ELS1 tail fuse
