1jz valve cover gasket... will a 2jz or 7m work?
mjtoll23
almost a TT-R
Apr 14, 2007
96
VA
Hello,
I need to replace the valve cover gasket on my 1jz. I read that a 2jz gasket will work, but I also read that a 7m will work? So which one is it?
Thanks,
Mike
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
No it's NOT a direct swap. The bolt holes are all off. I already tried this myself. The cover's slightly longer for teh 2JZ one too, as the first cam bearing cap is covered with the 2JZ cover, but not the 1JZ cover.
Nopaint
110
Jan 30, 2007
172
GA
1JZGTE engine parts
overhaul gasket set $ 138
cam cover gaskets $ 15 each
main bearing set .25mm $ 160
rod bearing set .25mm $ 78
flywheel $ 223
timing belt $ 21
T belt tensioner $ 46
starter $ 179
bellhousing for 7M $ 300
cam seals $ 5
rear main seal $ 25
oil pump seal $ 9
head bolt set $ 145
valve stem seal set $ 75
ignition coil set $ 384
crank position sensor $ 71
cam position sensor $ 71
Most 1JZ parts are available special order.
Jeff
1-800-327-2087
There ya go
