1JZ Throttle Body Gasket
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
the vvti version fits the non-vvti , the throttle body is bigger though. if you have access to 2jz gaskets i think it will be easy to compare if you have dimensions. let me know if you need them, i can send a pic as well.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
So the 2JZ works on the 1JZ then?
I just need to know what works, of course I can compare them if I need to, but I want to know what will fit before I take the throttle body off.
Jeff
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
the 2j one doesnt fit on the 1J
2J is more squared while the 1J is taller than the 2J.
dunno other cars that work tho.
I couldn't find one for mine either. I ended up having to make one out of gasket material. I'd love to have one if someone knows where they can be found.
