1jz tach signal
BigPants
Tucson, AZ
i cant get the rpm signal to read correctly on my safc. there are 2 signals coming from the ecu and i just tapped into one and it reads WAY too low. im afraid to experiment does anybody have any ideas?:1zhelp:
zoonwen
1JZ Supra
Apr 27, 2005
199
Denton, TX
I just used the pinout they provided in the wiring manual.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
its the black wire also you can do it just by plugging it in you dc power source i just had to calibrate my Gtech pro RR $255 through best offer http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4647825092 it works great ill put some dynos on soon!
Evilempire1.3JZ-GTE
Jun 22, 2006
1,382
SoCal
IG1 pin 11 black wire. The 1JZ haves only 1 signal. I think it comes from the ignitor.
Contact the Mfg. of the meter they should point you in the right direction from there.
You can try to change the cylinder setting the coil packs might use waste spark technology.
I think it uses 3 seperate pulses to fire 6 cylinders. So maybe try 3 cylinders.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
IG1 is the signal going TO the ignitor. Try connecting to the IGT signal beside it, which comes FROM the ignitor.
IF1 says "fire ignitor 1"
IGT says "I've fired an ignitor"
IGT will read 6x higher then IG1
