1jz swap
i am buying a 1jz front clip for a instal on a 88 mkiii na supra.
i know i need to extend harness.
but can i still have ac
what about the driver side fuse box (can i just swap the one from clip.)
dash wiring?
mkiv throttle cables (how do u install?)
mkiv power steering lines (how do u install?) do i need tt mkiv parts?
i would really appreciate any help. and pictures even more:icon_bigg :1zhelp: :ttiwwp:
JCP
The Big Unit
Apr 6, 2006
128
Raleigh, NC
I'll answer a few questions... for the rest you can either use the Search Option on these forums of just comb the following site over
http://www.jza70.com/articles/swap_the_basics/swap_the_basics.html
Check out the different links to those it has that have done the swap before...
Yes you extend the harness bout 18" although someone said you can widen the throttle cable hole in the fire wall and run it through there down to the ecu as is... but I have no experience with this... and I dont know exactly where it is on these forums.. but you can find it using search...
Yes you can keep your AC.. one of the lines you can use.. the other you have to have made..
Fuse box.. yes you have to change it and move around..
You can get 90% of your swap parts directly from Toyota.. but a few you may want to buy aftermarket like a beefy timing belt... etc... stuff that your going to want to change anyway you may want to look @ some upgraded options while your in there.. just depeds on your funds...
Anyways... check out that link and search through the 20 or 30 threads on this subject throughout supramania.. and all will be explained :).
Hope that helps!
