1jz swap with transmission questions?
supra941991
10
bossier city louisiana
ok so im out of cash, and im down to my last obstacle left in my way on my mkiii supra build. my last problem now is that damn transmission. i cant find an r154 under 200 and i have an automatic a340e transmission from my supra and my friend she gave me a w58 with flywheel pressure plate and clutch pedal and brake pedal. i know where there is a sc300 that i can pull the auto trans from the sc300 for 58 dollars but will the 2jz auto fit in the mkiii supra. or should i just buy the bell housing any input?
Gunnar
116
Belgium
www.chiptuners.org
sc300 auto is controled by the engine ecu ands the rear is different so your driveshaft won't fit.
I'm halfway an engine swap with keeping the original a340e transmission in a mkiii with 1jz vvti
