1jz swap runs perfect but leaking water
3.0 beast
25
Riverside
hello i recently just got done swaping the 1jz into the mk3 but its leaking a good amount of water and i wanna know if anyone has any ideas where it could be from..the leak looks like its starting from somewhere close to the water pump and is leaking down the block...i changed the water pump gasget and it wasnt that..also im getting a little water into the charge pipes? i was thinking if maybe theres any way dat it could be leaking from the turbo water lines dat could cause all this? help me out guys im ready to start driving my supra dis is all dats holding me bak thanx
f00g00
586
Kuwait
You can check the weep hole on the front neck of the waterpump for starters. You can also get a small hand mirror to look at the underside of the turbos to see if its the water pipes for them.
te72
Classifieds Moderator
6,618
9
WHYoming
Double check all your hoses and clamps as well. Did you replace the lines? If not, you may find yourself doing that sooner than later whether you want to or not. Ask me how I know that one. ;)
I've found that nearly all of my little water leaks over the years were due to my failure to properly tighten the clamps or get the hoses on far enough.
