High, im helping another SF/SM member on a 1jz install to an 89 chassis with pre-89 motor mounts, I belevie he posts here as brewster.
-On the power steering hose when using the 2jz unit, how is the orientation? Does it attach to the bottom of the motor like stock 1jz unit or does it clamp to the frame like the 7m?
-When wiring in the new harness, must the intack track be removed or does this only make it eaiser?
-On the A/C compressor I was told you need to use the top of the 7m unit?
I am very new to the 1jz swap and havent had much time researching the subject, if anyone could provide some good resources on this swap it would be greatly appriciated.
mike
mike
