1jz swap 2.0
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
Where do I start...I swapped a 1jz in my 1989 supra 6 years ago and I used it as a DD for 4 of those years. Last year I had two problems with the car a idling issue and a clutch issue. Long story short my 1jz had developed crankwalk. I pulled the engine and confirmed the crankwalk. I picked up a new 1jz up from Japanese Engine Import in Manassas, Virginia. I bought an auto 1jz because it's cheaper and I figure the thrust bearing would be in better shape being an auto. I'm going to swap all the 5 speed stuff over to the new 1jz. The pictures below show my progress so far. I super pumped to get my car back on the road, more pictures to come!!
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
1990MA70;2055298 said:
Nice looking swap. What kind of clutch were you using when you ran into the crank walk issue?
I was using a stock clutch. I'm going to disable the clutch switch to help reduce the chance of crankwalk again.
More picture too come, I've been working on putting A/C lines and A/C pump back on the car.
