1jz supra front clip won't start
liukc
Twin Turbo 7m
Phoenix, AZ
Hi guys,
I just started a new project and purchased a 1jz supra front clip. I comes with a 2 weeks start up warranty so I'm trying to start it in the clip and make sure everything is ok. It arrived yesterday and last night I began working on it. It has missing the 30a & 40a fusible links and the main relay so I replaced those, hooked up a battery and fuel pump. I tried starting it (by the key) and it cranks but doesn't turn over. I checked and it does not spark and I check the injectors with my noid light and they aren't firing. The ECU casing looks beat up and I'm wondering if it's bad. I can't check the codes because it has no gauge cluster. I checked and didn't see any missing connections, but does anyone have any ideas?
I greatly appreciate it,
KC
liukc
Twin Turbo 7m
Phoenix, AZ
honestabe;1223297 said:
If you can get ahold of a spare ignitor plug that in and see what happens. Put a fresh set of NGK 6097 plugs gapped at .022 Open up the ECU and see if you can see any burn marks or leakages.
Thank you for the quick reply. I will check the ECU tonight and I will like for a spare ignitor. I worry though that since the injectors are not firing that it might be more than the ignitor, which I think only controls the spark.
liukc
Twin Turbo 7m
Phoenix, AZ
10secdream;1223397 said:
Isn't the gap of .022 a little small? I thought stock gap was around 0.032.
Can you turn the engine over by hand?
Yes I can turn it over by hand. The compression is good and the motor spins freely when cranked by the starter.
liukc
Twin Turbo 7m
Phoenix, AZ
I had an inkling that it was ECU related as I checked and there was voltage to the ecu but not outputs. So I popped it open and it appears as if one of the capacitors has failed. I will replace it tonight and see if this fixes the problem.
Thanks,
KC
honestabe;1223401 said:
Several members are running .022 and their Supra's run fine. Each motor is a little different. For the 1J use NGK 6097's gapped between .022 and .028
Yeah .022 will be fine if you're running higher boost and maybe a standalone, but stock ecu should be from .028-.032. I do love the NGK 6097's though. Even if they were gapped to .022 it should still crank, but he has bigger problems than that.
To the OP, good luck.
When I got mine, my fuel pump relay wasn't connected........but that wouldn't keep it from firing. It would just keep you from getting gas.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
kind of what i had in mind. if its off it'll turn over, might even start for a split second, but it wont stay on thats for sure.
