Ok I got a 1j swap for a good price.so now its wired up and everything .my problem started when i went and put on my fuel lines.Im done now.... i go to fire it up and it wont start.so i was like let me check the timing,spark,and fuel.everything looked good....so i was like let me check the spark plugs.my #2 spark was loaded with oil and gas.so i change it to a ngk spark plug did couple cranks over and over to see if thats was my problem.I pulled out the ngk spark plug it was loaded with oil and gas.so i was like o.k. i need new rings for all my pistons.
my question is there or can be away to go around this?
(I had alreay cranked the motor over a couple time to get some oil moving around
so i know i did that right).
couple times it cranks over then just dies out
