1jz sc300 swap problems!
empera
Authorized Vendor
Philly.
ok so i posted this on clublexus but they arent much help over there so im hoping you guys will be able to help me with this.
so i just dropped in a 1jz into my sc300 out of a running mk3 supra...only things i did was change the timing belt, change the injectors to 550s with an mk3 resistor along with a engine harness and i'm using a chaser ecu.
The engine cranks but does not start. Doesn't look like im getting spark, fuel pulse or fuel pump....and theres no CEL
could it be the ecu? something in the harness?
any ideas?
