So last Saturday, I installed my Aeromotive AFPR kit. While I'm doing it, I notice a vacuum line to the power steering unit had popped off. (This line goes from the top of the p/s pump to the manifold, just behind the throttle body) Guess I was boosting better than I thought. :biglaugh:
Anyway, I get the AFPR kit all hooked up, fire it up and it runs great. Then I remembered that vacuum line. I put it on the pump, and the idle drops to 350, it's running rough, then it dies. I take the line off, and it's perfect. It doesn't make sense to me, maybe it will to someone here.
I need to get this sorted out today, because I need to get it tuned later this week. :1zhelp:
TPS Voltage is around 0.504V closed, max is 3.825V. Maybe there's a problem with the MAP sensor?
