1jz running bad when driving, fuel cutting out
cpo3619
5
Midwest
Hello, My engine ran fine then I took my 1jz out to do the clutch. I put it back in and now it idles fine but when you give it basically any gas it cuts out. You can drive it but you have to barely touch the gas pedal. My Wideband gauge goes lean to no fuel when you give it more then a quarter throttle and it cuts out. It has to be something with me taking the engine harness out and putting it back on again. Also the cam angle sensor got cut, but I wired it back together. Any help would be appreciated! Thanks
cpo3619
5
Midwest
Bump.
-Still runs terrible. Cant even give it hardly any gas. Idle seems ok but idle AFR's are like 10.5. Then when you drive it and give it gas, fuel cuts out
-replaced spark plugs and nothing happened.
-Fuel pressure is as it should be at idle.
-Has to be some sort of sensor problem or something. It ran fine before I took the engine out and did the clutch
