gearbox
can anyone help me in giving a probable diagnose before i dismantle the gear box for repair?
1. it gives out a sound like grinding metal after i've driven it hard and will stop when i press the clutch pedal, let it go, it'll sound again. when driving normally for whole day, there wouldn't be any sound.
2. when shifting, from 1st to 2nd, 2nd to 3rd, sometimes it feels like it'll push back or difficult to shift. down shifting when driving fast for 1st, 2nd & 3rd, it's hard to shift in. i have to force it in. what is the recommended type of gear box oil? range?
timing
1. it's running too rich now, have sooty deposits in exhaust tip & black smoke. exhaust temp meter shows between 200(idle) - 700c(speeding). how do i tune this engine? what gadgets do i need to access the comp box? it's already chipped when i bought the clip from japan
2. with air-cond on. idling around 900-1000, if i adjust the tps, it'll drop to 500 but engine will vibrate. how to get it idle at 650?
if i install a safc (the one with 5 buttons), will it help for the two problems above. it's drinking fuel like mad, pls help.
really a newbie with 1jz, any comments are really appreciated
timing
