1jz plug question
hurricanehyshka
21
edmonton
Hi,
Just wondering if anyone could help me out with my 1jz swap?
anyways thought I would just post here because once I get everything together I will post pics and such the usual I guess.
K here is a little back round on my swap set-up w/e.
1jzgte out of a supra auto, and im swapping it into my 1990 7m gte 5spd.
on my 1jz wiring harness there is a plug with 3 wires
big black with blue
big black with white
little red with black stripe and black brush marks
the reason im curious about this plug is that Im pretty sure that the black and white wire goes to the starter but what does that round connector plug into? there is also what looks to be like the same black and blue wire that is just all alone as you can see in that picture?
I will try and post a picture of it, I mostly just creep around but I cant find anything about this connector, or im a retard.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
yeah that is a tansmission wire for the auto. Basically, the black/ White and Blue/Black wire kinda loops around the Neutra start switch. If you look inthe harness, they are both split up at some point ( one end of the Blue/Black goes to the neutral start, then the other end of the Black white also goes to the neutral switch.
You can cut them off the plug and just join the two and you will have no problems. Also, there should be a split, either from the Black/White or Blue/Black which goes to the starter plug.
