I posted this up in the other forums but wanted to get your opinoins.
I purchased a jumper harness for my 1.5JZ swap to run a Aristo 2JZ ECU in my SC300 but the car is running like crap and I have a few questions. First off its throwing three DTC's- 21,31 and 47 which are the O2, Map and sub TPS circuits. The fuel pump stays ON with the key in ACC, engine OFF. I checked all the fuel pump relay pins coming from the 1JZ plugs to the 2JZ jumper and everything looks to be in order(2pins). Would the 12V mod cause the pump to run all the time with the 2jz ecu?
Other question is about the MAP circuit. How would I check this circuit? Does the 1JZ run the voltage as the 2JZ? Some of the guys on CL said it may be using different pinouts or voltage but I checked the pinouts and that doesnt seem to be the problem so Im thinking voltage.
The O2 issue, someone told me that the 1JZ uses the 2 wire sensor while the Aristo uses the 4 wire heated sensor and suggested I run the 4 wire sensor.
What do you all think?
